Removes an interface from RIPng routing.
| vlan-name | Specifies an IPv6 configured VLAN. |
| tunnel-name | Specifies an IPv6 tunnel. |
| all | Specifies all IPv6 configured VLANs or tunnels. |
N/A.
This command removes an interface from RIPng routing. However, the RIPng-specific interface configuration will be preserved, even if RIPng is unconfigured on the interface. The interface configuration information is removed only when the IPv6 interface itself gets deleted by, for example, by unconfiguring all the IPv6 addresses on the interface.
configure ripng delete finance
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.1.1 Licensing Guide document.
